someone have stock rom or remote file for this s805-box_ver1.0 2015.06.03
    as in the title,
    I have this box (mb in picture) but I cant find the real name.
    I upgraded to lollipop following the guide by Abdoul (thanks a lot),
    its all good also wifi, apart for the remote that's not working.
    So I need stock rom to come back to 4.4.2 or correct remote file to replace in etc folder.
    I forgot:
    original firmware was
    s502.1.0.1.20151120.release-keys
    kernel
    3.10.33
    ives@transpeed #4
    fri nov 20 02:59:29 cst 2015
    on google I had no luck finding only Chinese posts with no real link working
      Try this, it worked for me.
      mxqproject.com ist die beste Quelle für alle Informationen die Sie suchen. Von allgemeinen Themen bis hin zu speziellen Sachverhalten, finden Sie auf mxqproject.com alles. Wir hoffen, dass Sie hier das Gesuchte finden!
        i'll give a try, thanks a lot
          That worked, thanks so much!
