Xiaomi Youpin TIMEROLLS COB Quartz Watch - The Beauty of Minimal Design
    Xiaomi Youpin TIMEROLLS COB quartz watch is simple and generous, very suitable for young people to wear. The sunken dial design is literary and minimalist, covered by tempered glass, high light transmission and wear-resistant, not easy to be scratched. In addition to the luminous hands and scales, there is not any text. The watch case is made of 316L stainless steel, which is more resistant to friction and corrosion than the ordinary metal case. The movement is the most important part of the watch. This watch's watch movement is imported Citizen movement, which has the well-known stability and durability.
    Product Features:
    ● Simple but special sunken dial design.
    ● 7mm ultra-thin watch body.
    ● Tempered glass screen, solid as a rock.
    ● Imported Citizen quartz movement.
    ● Switzerland super-luminova powerful luminous coating.
    ● 30 meters of life waterproof to meet the daily needs.
    The TIMEROLLS COB quartz watch has a minimalist design with a leather strap that makes the watch elegant and generous, the included nylon woven watchband lets you change style at any time: https://gearvita.com/xiaomi-youpin-t...rtz-watch.html
    You may also like:
    microwear l8
    microwear x12
