Internal storage question on pmid701c
the internal storage is partitioned to 512m and 2.6g, and apps don appear to be able to see past that to the micro sd card so is there away in android to repartition that storage into one partition and mount the external card as sd, that would be great if I get alot of appsTags: None
Should be enough app room
I do know that the external card is kind of a bastard stepchild in this thing and not sure if/when that kind of functionality would be needed. But it should work just fine for the music and video you might want to put on the unit leaving all of that 2.6Gb for App space (some of your better ones could always be moved into the system memory). Now even if you only managed to find 20Mb apps (and those would be some big apps) you would have enough room for 130 of em. Not only would home space room start suffering if you tried to run that many apps at once, but your boot time especially would be horendous considering all the parsing it would need to do at boot.
There are currently 2139 users online. 1 members and 2138 guests.
