SONOFF RF Bridge 433 Makes All Your 433MHz RF Controlled Appliances Smarter
    SONOFF RF Bridge 433 controller can convert most of the 433.92MHz RF Remotes into WiFi wireless. By adding the RF wireless Bridge to iOS/Android App eWeLink WiFi wirelessly, you can add up to four 1-4 buttons 433.92MHz wireless RF Remotes or 433.92MHz sensors to the RF Bridge device. After pairing the 433Mhz RF Remote buttons with 433MHz RF controlled devices, you can directly control maximum 16 RF controlled devices on the App through WiFi/2/3/4G network.
    Product Features:
    ● Convert 433MHz RF Remote to App via WiFi.
    ● Make 433MHz RF devices remote controllable on App.
    ● Support to add max four 433MHz RF Remotes.
    ● Support to control up to 16 433MHz RF devices.
    ● Control 433MHz RF devices over WiFi or mobile network.
    ● Free iOS and Android mobile app eWeLink.
    ● Works perfectly with Amazon Alexa, Google Nest, Google Home.
    It can be used for most of the 433.92MHz RF Remote controlled products, like RF controlled switch, RF controlled socket, RF controlled bulb, RF controlled door opener, etc. You can set totally 8 schedule/countdown/loop timers to turn on/off the RF controlled products. Even more exciting is that it will work with the 433.92MHz door magnetic sensor, 433.92MHz human body IR sensor, and more other 433.92MHz sensors to realize security alarm, and allowing you to DIY smart scenes: https://gearvita.com/sonoff-rf-bridg...ontroller.html
    Hot sale products:
    mi band 4
    sabbat e12
