QCY L2 Wireless Bluetooth Earphones - Active Noise Canceling, 13 Hours of Battery Life, Magnetic Design
    With the design of most mobile phones canceling the 3.5mm headphone jack, Bluetooth headsets have sprung up. Two types of Bluetooth headsets have become the mainstream choice for the global headset market in the past two years: the neck-mounted Bluetooth headset and the true wireless Bluetooth headset. The latest QCY L2 is a neck-mounted Bluetooth headset that combines the advantages of both in-ear and collar-type headphones and incorporates active noise reduction, while keeping the price at only $32.99.
    Product Features:
    ● ANC active noise reduction, eliminating noise at 50-1000Hz low frequency, 25dB maximum noise reduction.
    ● Bluetooth 5.0 chip, more powerful high-speed transmission efficiency, high degree of synchronization.
    ● 12mm modified ferromagnetic high resolution speaker, supports AAC/SBC advanced audio coding, integrated cavity design, all-round sound effects.
    ● Built-in 210mAh battery, can play for about 13 hours, turn on the noise reduction mode for about 10 hours, standby for 20 hours.
    ● Lightweight U-shaped engineering design, high elastic meterial, long-term comfortable wear.
    ● Intelligent touch button to switch songs, add/subtract volume, pause/play, answer calls, without having to pull out the phone.
    ● Long press the multi-function button can wake up the voice assistant, one sentense to check the data translation, navigation, etc.
    ● Magnetic design, can be easily hung in the neck when not in use, prevents the wire from being entangled and not easy to slip, convenient to carry.
    ● IPX4 waterproof level, can effectively prevent the sweat and rain.
    The three most noteworthy aspects of the wireless neck-mounted Bluetooth headset are: battery life, wearing comfort, and sound quality, while QCY L2 can satisfy any of the above: https://gearvita.com/qcy-l2-wireless...earphones.html
    Recommended great QCY products:
    qcy t1s
    qcy qy19
