Beelink Z83V Mini PC - Dual Frequency Display, Compatible with Windows 10 and Linux System
    Beelink Z83V mini PC is an updated version of the well-known and well-proven Beelink Z83 II model, the main difference is the VGA port for connecting to the monitor. Thanks to the presence of two outputs (HDMI and VGA), the device provides the ability to use two monitors simultaneously. Z83V supports not only the Windows operating system, but also Linux OS, whose application compatibility is better.
    Main Parameters:
    CPU: Intel Atom X5-Z8350, 2M cache, quad core, up to 1.92GHz
    GPU: Intel HD Graphics 400
    OS: Windows 10 and Linux
    Storage: 4GB RAM + 64GB ROM
    Max Memory Bandwidth: 12.8GB/s
    Max Extended Capacity: 128GB
    Ethernet: 1000Mbps LAN
    WiFi: IEEE 802.11a/b/g/n, 2.4G + 5.8G
    Bluetooth Version: 4.0
    Decoder Format: H.263, H.264, H.265, HD MPEG4
    HDMI Version: 1.4
    Z83V mini PC brings you faster and lower interfering WiFi performance anywhere you go, its small form factor allows you to carry this device in your suitcase and backpack: https://gearvita.com/beelink-z83v-mini-pc.html
    Hot sale products:
    amazfit bip 2
    redmi k20 pro 128gb
