CWM and ROM Install (cube u30gt2)
I have a Cube U30GT2 10.1 RK3188 16gb, and I would like to know if "900supersport" rom v12 has CWM in it or is there a "link" to where i might download from, i have used cwm before on my "samsung" and it's a wondreful tool also can you even install this rom with cwm, i'm new to chinses tab's and i realy do not know anything about them, i'm just relizing these tabs are verry different than samsung and others. Android might be the same but they are different in the respect to chinese tabs, i need HELP!Tags: None
my roms come with stock recovery. Once you have flashed my rom with your chosen app space you can then flash funs CWM for the cube u30 gt2. You will find this at http://androtab.info/clockworkmod/rockchip/rk3188/.
Once you are on CWM further updates can be via CWM900Supersport
freaktab developer
Originally posted by 900supersport View Postmy roms come with stock recovery. Once you have flashed my rom with your chosen app space you can then flash funs CWM for the cube u30 gt2. You will find this at http://androtab.info/clockworkmod/rockchip/rk3188/.
I find WiFi reception acceptable, not as good as my laptop but OK. I've not used the Bluetooth at all. I use my laptop a lot less since getting the gt2.900Supersport
freaktab developer
There are currently 2180 users online. 1 members and 2179 guests.
