Isn't Max should be 2.2 ?
Beelink GT1-mini② Amlogic 905X3 4/64 Dual WiFi GIG Lan BT
Originally posted by mctiew View PostAnyone noticed or not, the DRM info based on the picture is current HDCP 1 and max HDCP is 1 too.??
https://i.imgur.com/qViXAwk.png
I would like an overall impression of the device... to buy, not to buy?
Stability? or glitchy/ buggy?
Heat, or throttling and reboots?
Ram efficiency, able to use multiple apps or windows simultaneously?
Solid running of all google suite, and related programs?
AV quality, minus the hdr and hdmi issues mentioned above?
Considerably better than the x2 chips?
Value, scaled 1 to 10 based on cost and class competitive devices?
... Do you like it, are you satisfied, is it...
a buyer, or an also ran? - thanks folks!
ClarkKent
To buy it or no it depends of yor needs. (e.g. I dont expect netflix to run so its good box for me). I personaly have no problem according to stability and performance but i don't use it for games, I also didn't notice any problem with excesive heat, 4GB of ram is enough to run couple apps at the same time, i have no idea how much better is it against x2 but i had s912 khadas vim2 and GT1m2 is much better device.
form 1 to 10 i would give it 8 now but i only have this device for a week...
form 1 to 10 i would give it 8 now but i only have this device for a week...MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I don't care about Netflix either, but appreciate the ability to mimic some mini desktop ops, and run various movie scrappers ....Cinema, Cyberflix, and perhaps an IPTV- if I can ever find an affordable well working one. I have become more than a bit apprehensive about Beelink products. I probably expect them to perform as promoted... which can be a bad starting point, I guess?Kris....don't forget my boxes! Okay?
What specific use case do use it for?
*ed: since you're one of the first to get one, I was hoping to see your follow-up impressions... am I looking in the wrong place? thnxKris....don't forget my boxes! Okay?
Originally posted by mctiew View PostDid you actually tested it ? (Sorry for the rather stupid question.) Maybe this is a? country specific problem.?
try...Test My Net, Runs from browser, but allow for a "widjet" IT'S a great powerful net testerKris....don't forget my boxes! Okay?
Originally posted by ClarkKent View PostMaybe so...US here, and not this model device. I've had a couple of non performing issues with okla...but long ago I don't remember what the solution was. Usually is Flawless. So, reload, reboot, permissions, yadayada?
Originally posted by mctiew View PostWhy certain speed test app such as Ookla speed test won't run and can't detect the nearest server ?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by ClarkKent View PostHAVE YOU TRIED THE SUGGESTED REMEDIES ? ....Look to your settings, or router for interferance. will it run from a browser (not dl app). What country?
You can check with another poster. He made this post and review, saying Ookla speed test is "truly incompatible" on this box :-
[attachmentid=10351922]Hi all... This is yet another humble real world review of the recently released (Around July 2019) Beelink GT1 Mini②. The picture above doesn't lie about its tiny dimensions. The GT1 Mini series are one of the tiniest "TV Boxes" out there. Definitely smaller than the Mecool M8S Pro L box and i already felt that was small enough. The GT1 Mini ② completely replaces the previous Beelink GT1 Mini. The major difference being the SoC bump from S905X2 to S905X3....
There are currently 1477 users online. 1 members and 1476 guests.
