[Rom]Minix Neo x7 By Gino - Multi-User & Multi-Window
    V1.3 ( beta)
    Fix loop minix logo
    V1.1
    More stable system
    Very Fluid
    Add kernel 1080 Overclocked (beta)
    Can play full 1080P Blu Ray Rips
    V1.0
    based on Oma Rom for v88
    Real multi-tasking.
    - Android 4.2.2
    - CWM 6.0.3.1 recovery
    - ethernet support
    - PhabletUi and TabletUi
    - init.d support
    - gameloft compatible
    - latest hosts, su, su-binary, busybox
    - MX Video-Player, Play Music & FX Sound
    - Reboot Menu, Kernel Tuner, Pimp my Rom
    - Nova Launcher
    Rom based on sdk 2 .
    100% compatible with apps in Google Play.
    System management modified for more compatibility on x7
    Be aware: it is your own risk!
    Link download:
    https://mega.co.nz/#!CR0EgRxC!AB51RHnCpasiDfpe9yr01zuR9NYj6gxIbEV2K-qz4VA
    WOW! Looks interesting... Any plans on porting it to X7mini as well?
      Hmmmm, interesting.Is this different from Strauzos multiwindows ROM?
      Sent from my Faea HY509S using Tapatalk 4
        Nice ... i'll give it a try tommorow
        Cristallx
          Whats the clock speed with this ROM's kernel?
          "Success is a lousy teacher. It seduces smart people into thinking they can't lose."
          - Bill gates
            Yes
              Just 1080 kernel overclocked 1,7ghz
                AW: [Rom]Minix Neo x7 By Gino - Multi-User & Multi-Window
                Originally posted by Gino View Post
                Yes
                Is there a sound device management included? Or support for more webcams?
                Can you please tell more about the differences.
                Gesendet von meinem LG-P710 mit Tapatalk 4
                  not yet but it should give us time, it is not perfect yet, we welcome your suggestions
                  the input managment system of android is not the bad implemented by Rockchip on stock rom, there is a lot of difference because this rom is a real android 4.2.2 rom
                    Hi Gino, how can i check the rom is sdk2?
                    Sent from my HTC One now Free
                      Test it and you will see
                        v1.2 on first post
                          How is the video playback compared with Strauzo's SDK2 rom and does it run apps like netflix NFL game pass and other streaming services better than Strauzo's Rom?
                          Sent from my iPad using Tapatalk - now Free
                            I'm not tested strauzo rom but video playback is very smooth for netflix and nfl ,you can try ...
                              Nice m8 you work fast. I will test again tomorrow.
