Transpeed TR99 Mini Original Android 8.1.0 Oreo Firmware
    Original Stock Firmware for Android TV Box Transpeed TR99 Mini (S905, 2GB RAM, 16GB ROM)
    This firmware is most likely suitable for Alfawise A9 (not tested, but the firmware from Alfawise A9 works on the TR99 Mini)
    File Name: S905M2_TR99_MINI_MP_20190414.img
    Version: Android 8.1.0 Oreo (June 2018 security patch)
    Links:
    Download from MEGA
    Download from Google Drive
    Amlogic USB Burning Tool is recommended for flashing (confirmed to work with version 2.1.7.0). Use Google to find download link for the tool.
    Flashing tutorial:
    To connect your Transpeed TR99 Mini TV box to your PC, use USB A Male-to-male cable. Plug the cable in the USB port FURTHER from the SD card slot. Before plugging the cable to your PC, hold the reset button (behind the A/V jack there is a switch, use a toothpick to press it). If the device is recognized, you can start flashing in USB Burning Tool.
    Root:
    Download from yadi.sk
    Put on SD Card or USB
    Flash UPDATE-supersu-2.82.1.zip via Update&Backup app
    TWRP 3.2.2:
    Flash TWRP322_AML_ViT.zip via Update&Backup app
    This is a temporary TWRP, it does not replace stock recovery
    For reboot TV Box go to Advanced-> Terminal. Write reboot.
    TWRP 3.2.3:
    Download from MEGA
    Flash this img file via temporary TWRP
    or
    Rashr - Flash Tool app (root needed)
    My devices:
    Okko SmartBox | S905Y2, Unlocked | ATV9 Slimbox ROM
    Firmware : Name File-S905X2-TR99-2+16G.rar Only TR99 X2
    https://mega.nz/#!OzYwkYIS!A53iRMCtp...UW_A2af9I99ZuI
    Android 9
      Firmware : Name File-S905_TR99_MINI0414.rar Only TR99 Mini
        TR 99 X2 Motherboard
        You need open de box for install new firmware.
        This box is compatible CoreElec. No WiFi
          Reverse side of board, comes off plastic case with 2 self-tapping screws.
          My box supports 2.4Ghz WiFi. Runs CoreELEC (Nightly-ng) perfectly, even CEC works great. Wow.
          Is Wake-On-Lan (Ethernet) supported on this board? How do I enable?
            TWRP 3.2.3 added
            My devices:
