HOW TO USE OSCAM AND POWERVU FUNCTIONS IN MECOOL K6 TV BOX
    Hey guys,
    Glad to share the using introduction for OSCAM and Powervu functions in MECOOL K6 DVB-T2/C/S2 HI3798MV200 TV Box.
    Please download the application and read the following introduction carefully before installing and using these two functions.
    Installation Steps:
    1.Using OSCAM and Powervu functions, the user needs to install a Supercam application. Download and copy the Supercam application to the USB device.
    2.Plug the USB device into the USB host of the box. Open the Supercam application after installation.
    Setup Active Supercam function to ON.
    3.Open DTV application and enter Installation-DVB S/S2 menu. Press the number ?1? button on the remote control six times and the box will enter the smart Data Manager menu automatically.
    How to edit and import OSCAM、PowerVu KEY?
    (1)OSCAM
    a. Create a new notebook file on the computer and rename it CCCam.cfg
    b. Refer to the format below to edit the CCCam account and save it. Copy the edited CCCam. cfg file to the U disk.
    c.Plug the USB device into the USB host of the box.,Enter the OSCAM menu and press the yellow key on the remote control to import the account.
    (2)Powervu
    a. Create a new notebook file on the computer and rename it Softcam.key)
    b.Refer to the format below to edit the Powervu key and save it. Copy the edited Softcam.key file to the U disk.
    c.Plug the USB device into the USB host of the box.,Enter the Powervu menu and press the yellow key on the remote control to import the account.
