Beelink GT1 - A TV Box 69.99 Gearbest
    Amlogic S912 / 3GB DDR4 RAM + 32GB ROM / 2.4G 5G WiFi / 1000Mbps / HDMI 2.0 / VP9 / H.265 / Supports HDR10
    Description:
    The Beelink GT1 - A featuring the latest processor. It is equipped with the Amlogic S912 CPU which enables you to have a smooth entertainment experience. It also has a 3D noise reduction filter.
    Main Features:
    ● Amlogic S912 CPU with octa core is rapid and stable, it can give you a high-speed feedback and smooth response.
    ● Android 7.1: comparing to the former version, people can easily install or uninstall applications and games.
    ● Dual Band WiFi: 2.4G plus 5.8G can improve the speed which can implement multi-task.
    ● 1000Mbps LAN can improve the net speed and the performance to a large extent.
    ● H.265 and VP9-10 Profile-2 decoding will offer you high definition pictures and movies.
    ● It owns the 3D noise reduction filter which is convenient for you to enjoy the high-quality entertainment.
    Note: the product supports , but you need to install it by yourself. This product doesn't support above iOS 9.0 systems miracast function.
    Note: the "Media Center" key on the remote control is merely decorative key, no function.
    Dont Delay Buy Today <<< Click
    https://www.gearbest.com/tv-box/pp_0...&lkid=43649626
    #1
    Gearbest TV Box & Mini PC Page
    #2 Flash Deals Flash Deals
    #3Coupons Coupons, Coupons and More Coupons
