Mecool M8S Max TV Box - Amlogic S912, 2.4G + 5.8G WiFi, 4K VP9 H.265
    The Mecool M8S Max TV box deserves attention, due to its capabilities and quite an attractive price. The main feature of this model is the presence of Android TV system with built-in voice assistant Google Assistant, which allows you to use all the advantages of modern system more comfortably.
    Main Parameters:
    CPU: Amlogic S912, Octa core, ARM Cortex-A53, 1.5 GHz
    GPU: ARM Mali-T820MP3, up to 750MHz (DVFS)
    OS: Android 7.1
    Storage: 3GB RAM 32GB ROM
    Ethernet: 10/100M
    WiFi: IEEE 802.11 a/b/g/n/ac, 2.4GHz 5.8GHz dual band WiFi
    Blutooth: V4.0 HS
    Video Decode: H.265 4K@60fps 10bit, VP9 Profile 2, H.264 4K@30fps, AVS 1080P@60fps
    HDR: HDR 10, HLG HDR
    Language: Chinese, English, Germany, Japanese, Korea etc. 24 languages
    OTA Update: Support
    For certain environments or uses, sometimes the passive ventilation of most TV boxes may not be enough and must be coupled by mod some fan. The Mecool M8S Max comes to solve these problems because it includes as standard an industrial grade fan with a large hole to evacuate hot air from the upper part: https://gearvita.com/mecool-m8s-max-...gb-tv-box.html
    Hot sale products:
    xiaomi pro wifi amplifier
    mi band 4 cn version
