Problem of CSA93 Plus 4G+ 64GB (System Rom Resolution set to 4K ) Error Screen and CPU?Usage about 80%-90%
    Hi All
    how can I fix 4K firmware (update_rk3328_R71_20190710.zip) can Smooth and Display
    thank!!
    http://keypoint.myqnapcloud.com:8082...i?ssid=0N1FQ88
    (System Resolution 720P Physical Size 1280x720 )---CPU Usage less 30%
    update_rk3328_R71_20190624.zip
    Function
    1. Root
    2.Screen Rotate
    3. Blank first boot logo
    (System Resolution 1080P Physical Size1920 x 1080 )--CPU Usage about 50%-60%
    update_rk3328_R71_20190709.
    Function
    1. Root
    2.Screen Rotate
    (System Resolution 4K Physical Size 3840x2160 )---CPU Usage about 80%-90% and error screen
    Function
    1. Root
    2.Screen Rotate
    Hello,
    So your problem is 4K Video Playback right?
    Have you checked in your Video player that he use Hardware Acceleration?
    When only Software is detected that can give you this error.
    Neomode
      Originally posted by kenyu View Post
      Hi All
      thank!!
      (System Resolution 720P)---CPU Usage less 30%
      Function
      1. Root
      2.Screen Rotate
      (System Resolution 1080P)--CPU Usage about 50%-60%
      Function
      1. Root
      2.Screen Rotate
      (System Resolution 4K)---CPU Usage about 80%-90% and error screen
      Function
      1. Root
      2.Screen Rotate
      Not sure what you mean.
      But if you put the frame-buffer as 4K(did you modify the resource.img for this?) then it won't work, only the RK3588 released next year supports true 4K desktop resolution and the Nvidia Shield currently.
      Video playing apps like Kodi can play 4K smoothly if the manufacturer added auto frame-rate switching, otherwise video playback will be jerky if played at the wrong frame-rates.
      RK3328 devices run smoothly at a frame-buffer of 720p(and a bit slower at 1080p), if you set the screen resolution to 4K, videos will still play at 720p/1080p but the Android UI will be smaller and fit better on a 4K screen. RK3328 and even the faster S922x doesn't support true 4K UI, only for video playback in Kodi if the manufacturer implemented it.
      If you are just using the stock firmware and didn't do any modifications then there might be a background app using lots of CPU usage.
        Maybe some app uses cpu power, i dont know this machine but maybe it cannot get much power due to lack of cooling ect.
          if we focus on the still picture, is it possibile for displaying 3840 x 2160 px (72 dpi) of image in jpg format?
