[ROM] Beelink GT1 Ultimate SN:LPN1 Android (7.1.2) ALVATECH
Thanks to ALVATECH for the work done, your firmware is much better than the Chinese curve, but it inherited one unpleasant moment. The frequency of weak processor cores is set to 100mhz and for the device to work smoothly it is necessary to install a program in which you can raise the frequency to 667mhz to a constant. I hope you take this into account in future firmware.
Originally posted by informator View PostThanks to ALVATECH for the work done, your firmware is much better than the Chinese curve, but it inherited one unpleasant moment. The frequency of weak processor cores is set to 100mhz and for the device to work smoothly it is necessary to install a program in which you can raise the frequency to 667mhz to a constant. I hope you take this into account in future firmware.
Thank you,
Alvatech
Beelink in the latest firmware, 709 710 and 711, an error was made with the processor frequency where the minimum frequency threshold is set to 100Mhz, which negatively affects the performance of the device, raising the minimum frequency to 667 significantly improves stability and eliminates friezes.
This is just a wish).
Thank you
Originally posted by informator View PostBeelink in the latest firmware, 709 710 and 711, an error was made with the processor frequency where the minimum frequency threshold is set to 100Mhz, which negatively affects the performance of the device, raising the minimum frequency to 667 significantly improves stability and eliminates friezes.
Thank you
Thanks again,
Alvatech
Very nice ROM, but I found 2 problems, that also are on original firmware:
1. Ethernet interface is unavailable after starting device first time (when I connect the power supply) - I can’t see whole Ethernet section in network settings, an Internet doesn't wok. This happened especially when WIFI is off. Internet becomes available only after rebooting. I tried to assign static IP address without success.
2. I tried to run device as WIFI portable hot-spot, but I can select 2.4 GHz network only. Hot-spot works at max 72Mbit/s only (probably in b/g mode).
A) Could you improve network speed at 2.4 GHz to at least 150Mbit/s (n mode)?
B) Could you add option to run Hot-spot at 5GHz (ac mode)?
C) Could you add an option to see devices in LAN for devices connected to portable hot-spot (I want to use DHCP server from LAN) or how to do that?
Originally posted by plocu View PostVery nice ROM, but I found 2 problems, that also are on original firmware:
Thank you,
Alvatech
Originally posted by ALVATECH View Post
If you are having these issues on the original ROM and this ROM too then there is not much I can do. Some of these issues need to be fixed through the source and we don’t have the source to this, and even then it still wouldn’t be that easy. What your asking for is a lot of different things that for the most part are limitations of the box and or software. Not just one thing. There is no simple fix for the different things your asking about. Some issues may also be due to your router.
Thank you,
Alvatech
I already wrote to Beelink support, but they gave me advice to reset to factory settings, upgrade software etc.This didn't help of course.
Thank you,
Alvatech
If your box is having some issues you might want to consider returning it if you've purchased it recently. If not see if there is anything else Beelink can do for you.
Thank you,
Alvatech
I think it is too late. I found another issue, some programs don't detect that internet connection is available when I'm using Ethernet. After switching to WiFi is ok. Should I write to the authors or is it problem in my device firmware?
Thank you,
Alvatech
There are currently 1915 users online. 0 members and 1915 guests.
