[ROM] Beelink GT1-A Ultimate SN:AGTA ALVATECH (Standard Android 7.1.2) Widevine L1 DRM (Netflix Certified)
Thanks for a good rom ALVATECH
Most times it works flawlessly, at times I get the "app not responding" message. I sometimes hit the wait option but a few seconds later it pop's up again unresponsive, I then get the "processes has stopped" message. I get this mainly when it starts up or when I use my browser. The only way to get out of this is by restarting the box.
The box is the original 3GB ram, I've checked.
Any help to sort this out would be much appreciated ?
sorry for the late response. This does not sound like normal behavior at all. More than likely you have an app that's incompatible running on your system or something in the OS got corrupted. Your best bet is to reflash it completely and install a few apps at a time and wait and see if it acts up. If it continues, you may have a hardware problem. It's just way to time consuming trying to figure out exactly what the issue is with all the different scenarios and different apps / updates. You can uninstall an app one at a time and troubleshoot it that way if you like. But I personally would recommend a re-flash.
Thank you,
Alvatech
Originally posted by ALVATECH View Post
Hello,
Thank you,
Alvatech
Originally posted by Hideiyoshi View PostCould someone with this box test if netflix HD works and what's the max resolution? ThanksMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 1945 users online. 0 members and 1945 guests.
