Vosen V1 Android 9.0 TV Box Media Player IR Control Hub for Smart Home
Main Features
● Android 9.0 operation system
● Amlogic S905X2 Quad-core ARM Cortex-A53 CPU
● ARM G31 MP2 GPU
● 2GB LPDDR4 RAM + 16GB ROM
● 2.4GHz + 5GHz dual-band WiFi
● 100Mbps Ethernet
● Support 4K ultra HD image display
● Support H.265 decoding
● LED indicator, smart breathing light
● IR control hub for smart home
● Control, monitor, and protect your home
