MOISTURE IN CHARGING PORT
I keep getting this error on my Samsung Galaxy Tab A. I cleaned the port with a little rubbing alcohol and Q-tip. I even placed it in a bucket of rice sealed tight. And lastly, I used an air can. Anybody have any suggestions. Samsung Support wants me to pay $129 dollars to repair it. I refuse to pay it. The Tablet will charge on but not off. Samsung cell phone owners are having the same problem. I think it is time to start a class action lawsuit to force Samsung to come up with a fix, patch or solution. This problem is solely with their products. Thanks for listening!Tags: None
hmm.. a friend of mine hat a samsung tablet ( cant remember model )
where the charge port broke..hey was about to throw it away
opening up the tabled : I found a ribbon cable connected to usb c
Ordered ribbon cable from **** 10 bucks.. easy fix
My best advice.. lookup your tabled (laptop) model on youtube/google
There you can find out : How to open up your device
There you can find out If its worth opening up the device ( see internals )
Cheers
There are currently 3209 users online. 0 members and 3209 guests.
