What is going on with my H96 Pro+ TV Box
Not sure,
Did this result from a firmware flash gone wrong?
Does Amlogic Burn Tool detect your China Box?
Did your have a power outage/ brown-outs/lightning ⚡ in the recent past(weeks)?
Check the polarity symbol on your power adapter,
(the polarity of some power adapters are reversed...so you would not get your China Box to turn on with these. Unless you chop and reverse the cables.)
Check the Amps(2.5-3)..too little and no boot-up.
Check the voltage (max 5V.)
There are currently 1842 users online. 0 members and 1842 guests.
