Touchscreen 0eef:0001 eGalax Touchkit driver help needed on kernel compilation
I have used an eGalax screen with the same USB ID, but I used the drivers built in to the kernel instead of the manufacturer's drivers. There are options in the kernel config to enable USB touchscreens, and eGalax support is one of the options. I can't remember if it used the usbtouchscreen module, or it's own module.... I think it was under the USB Touchscreen option.
You might try searching for the 'usbtouchscreen' module and give it a try. Some of the custom kernels/roms include touchscreen support.
custom flash
thanks
this names combined with x5 show up some results, i will test that in 2 - 3 hours and report.
The unit should be used as car navigation so touch, gps and remote control have the highest priority.
Builded up a power converter with can-bus control and remote emulation so i'm able to use the steering wheel buttons of the car to give the minix some input but up down left right enter back are a bit less for control...
There are currently 4143 users online. 1 members and 4142 guests.
