Mecool original OTA update files for M8S PRO / PRO+ / PRO L / PRO W and S905D KI PLUS S2 T2
Did you watch the update process carefully?
Best way is:
- insert card or USB stick with ota update
- entry the recovery mode (hit the menu key during power on multiple times)
- select update/upgrade from ext ( I'm not sure, how it's written exactly)
- navigate to the card or stick
- select the ota uprade zip
- watch the response carfully
-- the updater will check the version and checksums of the ota update
There are currently 3730 users online. 0 members and 3730 guests.
