Minix X5 Cant Be Rooted
    Hello,
    I have Minix X5. I want to root this device but while everything is good i can see superuser icon on menu. But, root explorer and other apps says that your device doesn't appear to be rooted.
    This is SuperOneClick and Moborobo Screens. I ve searched everything about root on this and other forums.
    hmm..
    did you run both appz at the sametime..
    because that doesn't work
    moborobe.. needs to be installed for the drivers
    then closed/quite.. before using any root tool..
    ps, i used Tpsarky.. with success on few devices..if oneclick fails
    cheers and goodluck
      Thanks for replying.
      Only i ve rooted with Tpsarky.
      Regards.
