Coupon:GBCN9JUF $59.99 <<< Click for this great deal
Main Features:
● Amlogic S912 CPU with octa core is rapid and stable, it can give you a high-speed feedback and smooth response.
● Android 7.1: comparing to the former version, people can easily install or uninstall applications and games.
● Dual Band WiFi: 2.4G plus 5.8G can improve the speed which can implement multi-task.
● 1000Mbps LAN can improve the net speed and the performance to a large extent.
● H.265 and VP9-10 Profile-2 decoding will offer you high definition pictures and movies.
● It owns the 3D noise reduction filter which is convenient for you to enjoy the high-quality entertainment.
●Note: the product supports , but you need to install it by yourself. This product doesn't support above iOS 9.0 systems miracast function.
●Note: the "Media Center" key on the remote control is merely decorative key, no function.
https://www.gearbest.com/tv-box/pp_0...&lkid=45624412 <<<< Click me
