Khadas Edge RK3399 Custom AndroidTV Pie Firmware
    This time an AndroidTV firmware instead of AOSP Android for Khadas Edge
    v1.4 Changelog
    • Add More Settings Menu in TvSettings
      – Use it to change fan speed or LED settings.
    • Add Fan and LTE drivers
    • Fix HD Audio passthrough in apps like Kodi
    • Add Disable sound in TvSettings menu
      – It can be useful if you use the tv remote to control the volume and don’t want a ir remote/airmouse or apps to change the volume.
    • Add 192Khz FLAC audio playback
    • Add extra gamepads like PS3/4, Xbox/Xbox 360/One, Nintendo Switch
    • Fix SDBoot - Use SDDiskTool v1.67 and Restore option to write firmware to a micro-sd card and for it to upgrade the emmc firmware easily.
    • Add TvSettings - Developer Options Flash image, Reboot Recovery, Reboot MaskROM Mode options.
      Click 7 times on About - Build Info to activate Developer Options.
    To Root
    Install Magisk Manager then patch the stock boot.img
    Unzip to get the app - https://github.com/topjohnwu/Magisk/releases/download/v20.0/Magisk-v20.0.zip 5
    Use Flash Image menu in developer options then select Boot and the magisk_patched_boot.img to flash it. Might need to do it twice if the boot partition is in use.
    Now you can restart and you will be rooted.
    No PC needed to flash a boot.img or recovery.img.
    When you want to unroot just flash the stock boot.img again or if wanting to upgrade to the latest Magisk code if some apps can’t get root or pass Safetynet anymore, just patch the stock boot.img again, patch it with Magisk and reflash it. Now you have the latest Magisk code again. Quick and easy.
    PS: Will upload the stock boot.img later
    Bugs:
    The resolution on bootup might not be right, manually change it to 1920x1080x60hz or 4K@60hz.
    Kodi only works with 24,25,30,50,60hz frame-rates in this image. 23.976hz frame-rates cause the UI to be slow and is disabled for now.
    I hope Khadas will be able to do some tests so I can fix this problem.
    Download link v1.4:
    https://mega.nz/#!BZthiQQL!UtSbDnjG5PPn9HPw37Bvdltre5WJwgDn1E4N7E5 TZy8 14
    Flash with FactoryTool v1.66
    v1.3 Changelog
    • Add VC-1 Video Codec Playback support
      ? Use MXPlayer then set the codec to H/W+ instead of H/W, make it the default in the settings
      ? Download the custom ffmpeg codec and set it as default in MXPlayer?s Decoder settings to have AC3/DTS sound. https://forum.xda-developers.com/devdb/project/dl/?id=28999 2
      Kodi can also playback VC-1 but sometimes you need to set the audio ahead by 1 second in the bottom right audio settings in Kodi while a video is playing. Not sure how to fix this yet.
    • Add Root with Magisk.
      Please read Useful guide for custom Android Pie firmware if you want to pass Safetynet for some streaming app support.
    • Fix Home button
      ? Double press for Recent apps screen
      ? Long press for All Apps screen
      ? Short press to return to the launcher home screen
    • Add auto mount for nvme storage (not sure if it works, will try to update if it doesn?t work)
    • Disabled forced encryption of userdata partition for a slight speed improvement
    • Video playback improvements
      drm/atomic: use active_only flag for connector atomic
      drm: bridge: dw-hdmi: signal none colorimetry for rgb output
      Fix activation of HDR mode on LG OLED
      drm/rockchip: hdmi: fix no sound some time
      drm: bridge: dw-hdmi: signal full range for rgb output
      drm: add picture_aspect_ratio to hdmi 1.4 4k modes
      drm: workaround for crash when trying to open render node
      vcodec: skip reduce freq
      Mali: midgard: fix the memory translation for aarch32
      drm: rockchip: dw-hdmi: only force YCbCr422 when max tmds is
      up to 340Mhz
      drm: bridge: dw-hdmi: signal it content and content type
      drm: bridge: dw-hdmi: default to underscan mode
      drm/bridge: icn6211: Fix pll setting make the output clock
      freq more accurate
      clk: rockchip: fix round rate
      phy: rockchip-inno-hdmi-phy: add vesa dmt pixel clocks
      WIP: mm: dma-mapping: increase dma pool size
    v1.2 Changelog - First AndroidTV UI
    • Add support for virtual batteries
    • Add camera imx214 driver and iq
    • Fix some apps that had black bars on the right side
    • ddr: update version to v1.28;
    • update drm/rockchip: cdn-dp
    • kernel: cdn-dp: ignore firmware fallback mechanism
    • Add LatinIME keyboard to be selectable in Keyboard settings for French(azerty) and German(qwertz) users
    • Add Appdrawer to run sideloaded apps not meant for AndroidTV
    • Add favorite apps to App row
    • Fix volume changing not working on AndroidTV
    • Fix Google Search crash
    • Updated Google apps to fix ATV Store not downloading problem
    • Some other changes, removed non compatible changes made for AndroidTV to work
      Use the Channels app to put Youtube channels on your home screen
    v1.1 Changelog
    • Add 10-Bit H264 video playback support in Kodi 18(not even Vim 3 can play these videos smoothly
    • New Recent Apps menu(Long press OK on a window to close it, long press back to close all recent apps)
    • Fix shutdown with ir remote(Long press power button to power off or restart)
    • Enable permissions for installed apps so you don?t have to enable it for all apps manually(Disable permissions not wanted if needed)
    • Spoof ethernet as wifi (Now you can play games like Asphalt etc. that only work on wifi over ethernet too. Some apps only added wifi support since phones/tablets don?t have ethernet)
    • Extra speed improvements
    • Add SYTV(add-free Youtube), Kiwi browser, Netflix apps
      (Kiwi browser can use Chrome addons just like the PC Chrome browser)
    • Removed a lot of bloatware apps that were meant for tablets
    • Block some ads by default to browse faster
    • Add kernel support for NFS, Samba v2(MiXplorer + Samba v2 addon is already installed)
      (To use Samba v2, use a file manager like MiXplorer, most apps only use Samba v1 with slower speeds and follow this guide - https://androidpctv.com/tutorial-connect-android-pc-windows-samba/ 1)
    • Changed default keyboard app to work better with an airmouse, it follows mouse movements.
    • Fixed Keyboard - Physical keyboard - Show virtual keyboard(Now you can enter the wifi password correctly if using TvSettings with the onscreen keyboard if using a mouse)
    v1.0 changelog
    • Fixed Kodi crashing
    • Add Kodi auto frame-rate switching
    • Fixed Youtube freezing problem
    • Added fractional frame-rates 23.976hz( Can be useful for apps like Netflix to play smoother)
    • General speed improvements
    • Add writing to external storage support
    • Made HDMI Bitstream audio the default to not manually set it if using passthrough audio
    • Fixed apps running sideways
    • Removed battery icon
    Download link:
    https://mega.nz/#!wJcimKIZ!2xgWoh6p9qpw3o4fvQChHP7hzepSJPA1ZQ0pF1s 8px4 7
    Pass: khadas
    Homescreen
    Homescreen.jpg1920?1080 990 KB
    All apps screen - Long press Home to see
    All_apps
    All_apps.jpg1920?1080 357 KB
    Recent apps:
    Long press back to close all or long press OK to close a single window
    57
    2019_07_25_04.18.57.jpg1920?1080 80.5 KB
    Bugs: To enter the wifi password just Double press Enter if using an airmouse or keyboard then Search on the right side on the onscreen keyboard to complete.
    Please let me know of any good open-source apps that work well for
    Podcasting, downloading, ebook readers, streaming apps(not region locked and available in Google Play Store), File managers, Video playback, Audio playback etc. then I can perhaps use them in my ROM's.
    I have been playing with this ROM on the Edge+Captain. Very nice work. ROM picked up a formatted NVMe drive without effort.
    While I am more of an AOSP type, this ATV ROM is impressive for the breed.
    Thank you for your effort on this mo123.
    • mo123
      mo123 commented
      Editing a comment
      Thanks. You're the first to comment NVMe drives get detected. I don't have one so it was difficult to know if it worked or not.
      I'll see if I can update the AOSP ROM later with these new changes.
      You know of any good launcher that works properly on tv boxes and Android 9 perhaps?
    ATV PRO works nicely for me on 7.1. Good settings and features. Needs an ap drawer, or sorting of app types by purpose. Batch configuration of icon would be a big plus...but personalization is quite variable .
    Smooth, stable, reliable in the n6 hostile environment . Ha! Gotta be a plus. Pretty lite footprint too.
      V1.4 firmware link and info added.
        Thanks mo123, look forward to trying it.
          Would this work on my rk3399 Rtv-99/csa96 box? thanks
          • mo123
            mo123 commented
            Editing a comment
            Probably not since the hardware is different.
