Here we go with the next Item for you.
It is the Xiaomi Mi 4A Dual Band Router in the Gigabit Edition, this Router is the best you can get for your money.
With his Integrated signal amplifier, wider coverage and faster transmission distance.
Main Features
●1 x Gigabit WAN port + 2 x Gigabit LAN ports, easily meet the fiber broadband of 100M and above access requirements
●2-core 4-thread CPU, 880MHz main frequency, fast internet access, and fluent internet surfing
●1167MHz dual-band concurrent rate, no-interface
● Same name for dual-frequency, automatic access the optimal frequency
● Integrated signal amplifier, wider coverage, and faster transmission distance
● 128MB large memory, support 128 terminal devices connection
● Intelligent error correction algorithm to improve weak signal
● manage your child's online time and content, protect your child's Internet security
● Set the device's networkable time and the range of URLs allowed to access
Specifications
- Processor: MT7621A MIPS Dual Core 880MHz
- ROM: 16MB
- Memory: 128MB DDR3
- Dual frequency 2.4GHz and 5GHz
- Wireless channel: 2.4GHz Channel: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13; 5GHz Channel: 36, 40, 44, 48, 149, 153, 157, 161, 165
- Manage APPs: support Web, Android, iOS
- Working environment temperature: 0 - 40 Deg.C
- Working humidity: 10 - 90 percent RH ( non-condensing )
- Storage temperature: -40 - 70 Deg.C
- Storage humidity: 5 - 90 percent RH ( non-condensing )
You can Buy it here for only $35.99 with the Coupon Code GBCNXG01
