i have a wrong USB Chipsets in to the BIOS used.
All USB Port are not useable.
All USB port's have 5 volt, there are not bricked
then I noticed that the bios battery is empty and they exchanged for a new and connected. the stick and windows start normally
I have found a guide to clear CMOS on beelink forum
my steps to clear CMOS.
1 Power of / remove all cable and USB plugs 2 remove the Batterie cable for exakt 30sec
3 First the Batterie and then the Power cable Connect
4 Pocket PC boot Into windows
CMOS Not clear
1 remove the Batterie cable for 8h
2 Connect the Batterie cable und Power on
CMOS Not clear
what do I have to do, in what order do I have the BIOS reset (clear cmos).
Best reguard
