So, i have an m8s+ android box that my dad gave to me because it was bricked. I tried plugging it in to see what was the problem. The box was stuck at the TV BOX logo (not the boot animation when starting android). I tried the reset method to see if it will fix it, but instead, the box won't boot. I tried the best that i could do, didn't work. Then i decided to give up. After 4 months, the box decided to stop working. No blue light was coming from the box. So i tried again with the sd card method, shorting pins, nothing worked. So i decided to ask here for help, but i think that the box is a clone. I will attach the pictures later when i come back home. Any help?
M8S+ bricked (maybe clone?), no blue light or picture after 4 months.
Hi, i registered like 3 minutes ago.
So, i have an m8s+ android box that my dad gave to me because it was bricked. I tried plugging it in to see what was the problem. The box was stuck at the TV BOX logo (not the boot animation when starting android). I tried the reset method to see if it will fix it, but instead, the box won't boot. I tried the best that i could do, didn't work. Then i decided to give up. After 4 months, the box decided to stop working. No blue light was coming from the box. So i tried again with the sd card method, shorting pins, nothing worked. So i decided to ask here for help, but i think that the box is a clone. I will attach the pictures later when i come back home. Any help?Tags: None
Originally posted by neomode View PostHello and welcome,
If it is a real M8S+ then it has the S812 CPU.
The firmware for the Probox EX+ should work for unbrick.
Ray
So i've tried the firmware you said (Probox2 EX+) but nothing on the screen still. Can it be the u-boot file causing it?
Do you know any u-boot file for it?
By the way, here are to photos of the box:You may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
The M8S+ one or the M8S one??
There are currently 2448 users online. 1 members and 2447 guests.
