We are happy to do a bit of a Show on tell on the Beelink J45 Mini PC
Also You can win one of these with he competition that is running.
Check out the Beelink Thread or click link for details more details
https://forum.freaktab.com/forum/advertisers-and-vendor-support-area/beelink-azw/779880-beelink-j45-for-free-august-1-thru-august-10 << click me
Be quick only from August 1 thru August 10 you Snooze you Loose
As Usual with Beelink Products well packed and all the Bits to make it happen
Let's have a look see and what we have:
Main Features
● Intel Apollo Lake Pentium Processor J4205 ( 2M Cache, 1.5GHz up to 2.6GHz )
● Intel HD Graphics 505 GPU
● 2.4GHz + 5.8GHz dual-band WiFi
● 1000Mbps Ethernet
● Support 4K ultra HD image display
● Support H.265 decoding
Specification General:
Brand: Beelink
Type: Mini PC
CPU: Intel Pentium J4205
Core: Quad Core
GPU: Intel HD Graphics 505
Max. Extended Capacity: TF card up to 64GB (not included)
Media Supported
Decoder Format: H.263,H.264,HD MPEG4
Video format: 4K,DAT,ISO,MKV,MPEG,MPEG-1,MPEG-4,RM,WMV
Audio format: AAC,APE,FLAC,MP3,OGG,RM,WMA
Support 5.1 Surround Sound Output: No
Product Details
5G WiFi: Yes
Bluetooth: Bluetooth4.0
Power Supply: Charge Adaptor
Interface: DC Power Port,Earphone Jack,HDMI,LAN,Microphone Jack,TF card,USB3.0
Antenna: Yes
Camera: Without
DVD Support: No
HDMI Version: 1.4
Other Functions: Others
Power Consumption.: 12W
RJ45 Port Speed: 1000M
Power Requirement
Power Type: External Power Adapter Mode
Dimensions and Weight
Product weight: 0.3000 kg
Package weight: 0.7610 kg
Product size (L x W x H): 11.50 x 10.20 x 4.30 cm / 4.53 x 4.02 x 1.69 inches
Package size (L x W x H): 12.20 x 19.50 x 5.50 cm / 4.8 x 7.68 x 2.17 inches
Package Contents
Package Contents: 1 x Mini PC, 1 x Power Adaptor, 2 x HDMI Cable, 1 x Bracket, 1 x Bag of Hard Disk Screws, 1 x English Manual
Not a Power House But plenty enough for Home, Small Office, Kids and Homework, Internet and some Basic Gaming for sure:
Very small and Compact Unit can be mounted easy with Vesa Style Mounting bracket Supplied:
Lets have a look see:
The Box:
What's in the Box: Vesa Type Mounting Bracket, Screws for Bracket and adding extra HDD: SHort and Long HDMI cable
Power supply
Off with the base: Space for a SSD dive.
Casing:
Remove the PCB:
Ports: Plenty USB Ports Front and Rear
Two HDMI: Ethernet and Power and USB
One Side: Extra slot M2 under Current 512 stick
Other Side: we can see RTC: SD slot and see Plug for another HDD.
More after i work out how to get it all back together:
Don't forget you chance to Get one of these little beasties for Free <<< Click me
More Discussion will be found
FREAKTAB <<<< Click
