Xiaomi XiaoVV XVV-1120S-A1 Smart Panoramic IP Camera - Multi-module Function Free Combination
    The monitoring area of XiaoVV A1 panoramic camera reaches 360? comprehensive coverage, allowing your angle of view to reach the place that is not usually available. Mijia APP supports multiple viewing modes, such as 360VR, reel, columnar, quad split screen, and dual split screen, which you can switch at will. Join the upgraded AI humanoid detection, the alarm accuracy rate is up to 98%, you can view the home dynamics anytime, anywhere through your phone or tablet.
    Product Features:
    ● Mijia APP control, multi-layer technology encryption, protect personal privacy.
    ● F2.0 large aperture lens with IR-CUT automatic double filter, the maximum visible distance can reach 9m.
    ● AI humanoid detection, effectively filter invalid alarms, the alarm accuracy rate reaches 98%.
    ● Two-way intercom, open the camera operation interface and press and hold the talk button to make a two-way conversation.
    ● A combination of a variety of socket accessories, easy to operate, can be placed in the desktop, window sill, bed, also installed in the wall.
    ● Playback the video on phone as long as there is a network.
    ● Support multi-user sharing, multi-device remote viewing.
    ● No complicated setup is required, just plug in the power, download the Mijia APP, and follow the instructions for adding a device.
    XiaoVV XVV-1120S-A1 panoramic camera is here with the goal that you can see your home from all edges to ensure that your home and your family remain secured when you're not at home: https://gearvita.com/xiaomi-xiaovv-x...ip-camera.html
    Hot sale:
    edifier w200bt sale
    microwear h8 sale
