I create AndroidTV ROM for this device, based on that ROM.
It was modified to support our device and added app for DTV view from stock ROM at March 2019.
Also added:
- Support for init.d scripts.
- Some tweaks for net, UI, GPU and other.
- Android UI at 1920x1080.
- Youtube support to 4K.
- AFRD (auto frame rate demon)
- ES File Explorer and SPMC mod witch closed player on exit.
- Fix "NO LICENSE" issue on DTV view on some devices.
- OTA Update app from stock ROM.
- Used stock recovery, not TWRP.
To flash ROM use stock "Update" app to local update, or enter to recovery by toothpick.
Downloads:
YandexDisk
GoogleDrive
If you wish switch Android UI resolution back to 1280x720, flash this patch - resolution_change_for_mecool_m8s_dvb.zip.
When flashing, it switches the resolution between HD and FHD and vice versa.
