Recommendation widget is working play back setting is working did a little bit of editing today 10-19-19 Mod 8 update I think this is My final editing on this firmware everything is working smooth playback sound keyboard video amazing I think this one is done editing
Minix.Neo.U9-H Modify 2. Different design and wallpaper update 8-7-19 Final
SCV1-ATV-A7.1.2-Minix.Neo.U9-H Bass on the new firmware from minix home page just came out from beta took level 1 and didn't move whole bunch of files Modify 7 . Keyboards working sound fix you don't have to go to settings to set up sound
antonio, what is the diff between the 2 files?
also, i installed your Mod 6, the red version, i like it a lot
i have a problem, ethernet goes to sleep after certain inactive time...
in all fairness, i have had this problem with other modded roms, but not with original rom
also, no modded roms, included yours have the virtual keyboard default action key at ENTER by default...
what i mean is: when typing on A3, if I press ENTER, a letter T is added, because the default cursor is at that letter...i don't know how to fix it
i have to use the air mouse or/and arrows keys to go to ENTER...not the end of the world, i'm just curious if it could be configured
Originally posted by Lundy R View Postantonio, what is the diff between the 2 files?
Today August 21st edit firmware the video quality better then the original one I move so much file from different firmware that I've lost track but is working real good channel change fix Recommendations
Firmware has been updated from the new betta firmware that just came out from minix home page took level 1 did move files from beta a whole bunch of files and put it on this firmware mod 8 last update on this firmware edit today 10-19-19Last edited by antonio6o6; 19 October 2019, 23:45.
There are currently 2013 users online. 2 members and 2011 guests.
