Mecool M8s Pro Plus doesn't show up on burning tool and no reset switch
If you have positively identified the "Reset Button" location then use a small wire to Short the Positive and Ground solder pin points, While tvbox board is connected by USB cable to PC.
I am also sure somewhere else in this Forum, like maybe the "Enter MaskROM Mode" thread to Short-the-Pins for Amlogic devices probably has your board posted with the correct pins to Short to enter Mask-ROM mode.
There are currently 2146 users online. 0 members and 2146 guests.
