Huami Amazfit GTR Smartwatch - 42mm and 47mm Versions, 24 Days Battery Life
    Huami presented the new Amazfit GTR, which is offered in two sizes: a 42mm model with 1.2-inch, 390 ? 390 screen and 195mAh battery, and a 47mm model with 1.39-inch, 454 ? 454 screen and 410mAh battery. What stands out about Huami's smartwatch is, of course, the battery life. The smaller model is backed by enough battery power for 12 days of normal use or 34 days of basic watch mode. The larger model gets up to 24 days of normal use or 74 days of basic watch mode.
    Product Features:
    ● Display: 42mm - 1.2'' ( 390 ? 390 pixels)/47mm - 1.39'' (454 ? 454 pixels) AMOLED screen with Corning Gorilla Glass 3 protection + AF Coating
    ● Strap Width: 42mm - 20mm/47mm - 22mm
    ● Dial Thickness: 42mm - 9.2mm/47mm - 10.75mm
    ● Sports Mode: 12
    ● Connection: WiFi, Bluetooth 5.0 LE, NFC, GPS + GLONASS
    ● Charging Method: Magnetic charging stand, 2Pin Pogo Pin charge
    ● Waterproof: 5ATM/50 meters
    ● Battery: 42mm - 195mAh LiPo, 12 days daily use mode, 34 days basic watch mode, 22 hours GPS continuous mode/47mm - 410 mAh Lipo, 24 days daily use mode, 74 days basic watch mode, 40 hours GPS continuous mode
    ● Sensor: BioTracker PPG bio-tracking optical sensor, 6-axis accelerometer, 3-axial geomagnetic sensor, air pressure sensor, capacitive sensor, ambient light brightness sensor
    ● Compatible with Android 5.0 and above, iOS 10.0 and above
    In terms of design, the 42mm model is available in black, red, white, and pink standard versions, each only 25.5g in weight, while the 47mm model comes in aluminum alloy (36g), stainless steel (48gram), and titanium (40g) versions. Applying the coupon code "gtr47", you can get the 47mm model with the price of $129.99.
    Amazfit GTR 42mm: https://gearvita.com/huami-amazfit-g...atch-42mm.html
    Amazfit GTR 47mm: https://gearvita.com/huami-amazfit-g...atch-47mm.html
