[ROM] SC VIM3 Pie ATV Debug/User builds v2 20200117
You can download it here: https://forum.khadas.com/t/rom-sc-vi...0200117/4847/1Last edited by superceleron; 13 February 2020, 09:57.Tags: None
- Stuck
You are an amazing person, supporting the Amologic tv box. I follow you along with the h96proplus and now I have a gtKINg, I have a query. This version is compatible with the gt king B922x ?, greetings
Originally posted by alexjo View PostYou are an amazing person, supporting the Amologic tv box. I follow you along with the h96proplus and now I have a gtKINg, I have a query. This version is compatible with the gt king B922x ?, greetings
But dont worry, i am going to make a rom like this to the gtking B922 version.
Hi SC,
Been a while since I posted here but got my VIM3 a couple of days ago and seen that your are still hard at work making awesome roms.
I don't have a Khadas remote and cannot pass the setup screen, I have a microsoft wireless kb/m combo that I generally use for setup on my N2 and now the VIM3 but when entering the WIFI password at setup I cannot progress.
If I press enter/return it just tabs between the password field, hide password and back to the main screen. I can highlight complete with the mouse cursor also but cannot left click to select it, right click does work as a back button however.
I have some remotes from an older box and the remote.conf and rc_keymaps (Mecool S912 M8spro) but the customization tool is still not updated to unpack these images and add them in.
I've ordered a Khadas remote but will take quite a while to get here from china so wondering if there was a fix I could use?
Does the old manual method of sparse unpacking the system.img and repacking from android 7.1 work on the newer system images? It's been a while but could probably figure it out again if needs be...
Cheers, E.
Thanks both.
No remote like that unfortunately, the kb/m combo is wireless plugged in to usb, it is not hardwired but the receiver is plugged in to usb.
I have used that keyboard on other ATV versions to complete setup on different amlogic boxes.
If the kb issue does not have a fix then can how I unpack/repack the image? I can try myself to get it working
There are currently 2002 users online. 0 members and 2002 guests.
