KM8pro (S912) android 7 firmware
Ok guys,I think I may have something of interest for some of you...Android 7 firmware from videostrong!! Problem is,it does NOT flash onto android 6 boxes.You need to have flashed either the modified BB2nonPro via TWRP or if you have it the ota android 7 from vidstrong first....I done the BB2 first,then managed to get android 7 fw from manufacturer later so I then had to mod the KM8 Pro ota use TWRP for that and I could then flash the latest fw image straight to KM8 Pro and all is well...Proper android 7 KM8 pro.I think I am currently uploading the correct file to MEGA,I will post the link when it is complete.. Firmware is KM8PRO-userdebug 7.1.1 NMF26Q 20170818.170921-nov.V0321.. Upload failed,,,good thing too..Latest android 7 from videostrong is KM8PRO-ota-20171102.143544.V0928 again only write to existing androi 7 boxes.I have original unmodded file to flash to existing android 7 KM8 and a modded version to flash via TWRP to BB2 modded android 7 boxes to change them back to KM8.. You do lose the intro tune by the way..I will upload files to MEGA if needed,just let me know if you want them...Hope this may help some of you out there..LATEST firmware seems to be ota-20171102..Last edited by TommyM66; 13 August 2019, 04:01.Tags: None
Original KM8PRO ota file unmodified for existing android 7 boxes...
moz-extension://9d4dc802-8df1-491c-9987-0ca875084d12/mega/secure.html#fm/LHhCSACK
I hope link works for you....
If you know how to modify the file it will work for BB2 (non pro) boxes also using TWRP....
Link for modified file to follow for use with BB2 android 7 boxes.....
Using non broadband internet for this,upload is 80/100KBS so is waaaayyyy slow..I will upload modified file later,going fot some sleep now..
Both modded and un-modded ota zip files now on MEGA..Simplest way to get to android 7 is to flash BB2 non Pro android 7 img file and then use TWRP to flash modded ota zip file...Last edited by TommyM66; 13 August 2019, 14:02.
There are currently 2728 users online. 0 members and 2728 guests.
