GT king revision 922x and B922 - Ethernet Problem - Hardware Problem - Possible Fix
Not all GT king box, can use usb2ethernet adapter , finally Beelink accepting that are problems with ethernet with some of the box and advice to:
For this question, please contact our after-sales service mailbox
[email protected]
How exactly do you fix this ? From what I am reading it sounds like remove the installed 22 resistor and either solder across the identified connector or use conductive adhesive.to join the 2 points. I am assuming that would have the same effect as using a jumper. Is this correct.? I ask as I have a B922 box that gets connected at 1GB internet intermittently - sometimes connects sometimes not so I am using a 10/100 lan switch to circumvent it at present. Would prefer to get back on 1GB.
Originally posted by sesdave View PostHow exactly do you fix this ? From what I am reading it sounds like remove the installed 22 resistor and either solder across the identified connector or use conductive adhesive.to join the 2 points. I am assuming that would have the same effect as using a jumper. Is this correct.? I ask as I have a B922 box that gets connected at 1GB internet intermittently - sometimes connects sometimes not so I am using a 10/100 lan switch to circumvent it at present. Would prefer to get back on 1GB.
But i recomend you contact beelinkservice.
Originally posted by sesdave View PostDo they ever respond? Think I will order a usb3 ethernet adaptor try that and if it works then try the resistor removal and solder. At least I will have a backup then. Hope beelink get there act together and ship non defective models. This should have been identified before release
Originally posted by tombraga View PostI installed now Nova Prime, but the same as with the stock Beelink rom. I cannot delete or add apps on the homescreen, dont know why. I use HP wireless BT mouse, it works perfect in stock rom
ALVATECH can you tell me if i make something rom? normally i delete an app on the homescreen holding pressed left mouse button, then appear popup with delete option, but in your rom, nothing happen
There are currently 2098 users online. 0 members and 2098 guests.
