I've installed apps that make notifications appear at the top of the screen (Messenger / Line etc.) When I get a notification I can pull down the drawer, which I do sometimes just for fun..
Today I saw the "Switch Users" option and thought I'd check it out.... Big mistake. I didn't know that you can not switch back again. I was dumped into the same New Box setup screen as when first turn on the box, and had no choice than to do the setup, since then I've been trying to find a way out, the box will reboot to the main account where I seem to have full access for about 20 seconds then it says "Switching User" in the middle of the screen.... loop. There are no options in the settings menu for Users other than the google account kind of user. I have a few tools installed some of which I understand a little. Developer options, a Terminal, if those are useful, I have managed to boot to safe-mode, no difference, even got into the Debug menu, but nothing there than the option to wipe seemed of any use. I do not want to wipe the box.. I do however want to try an alternative firmware and have been lurking here for months trying to figure out which would work and whats different, highly unsuccessful at this because it's a real jungle in here, learning curve high even for a long time technician and electronics bug.
Anyway if you go this far, and have any suggestions I'd be grateful and will try to give back when I can.
