PLEASE HELP
alfawise T9 4GB/64GB TV BOX
Originally posted by slimdee View PostPLEASE I NEED THE SHORT LOCATION FOR MY ALFAWISE T9 TV BOX
PLEASE HELP
Why flash another device's firmware to it if you don't have a backup of the current firmware?
Search for 2 gold dots and short them, if such a thing is not available it will be very hard to get any instructions to enter MaskROM Mode.
Guest
Originally posted by linuxerwang View Post...I shorted that two pins and successfully put it in MaskROM mode. But still the firmware tool failed at "test device" step...
1. open Rockchip Batch Tool and import firmware
2. short two golden points under NAND chip and keep it shorted
3. plug the micro USB cable into OGT port
4. windows should make "add device" sound and device should appear in Batch Tool
5. unshort golden pins
6. press Upgrade to start flashing
Originally posted by linuxerwang View Post...I have a UART, can you please point out where might be the pins for GND, TX, and RX...
UART for Amlogic, Allwinner and Rockchip Devices – Setting Up Guide
I took some time to try. I think the PINs are correct because there are some texts output on screen. I tried with both minicom and picocom. Here are the outputs:
$ sudo picocom -b 1500000 /dev/ttyUSB0
picocom v2.2
port is : /dev/ttyUSB0
flowcontrol : none
baudrate is : 1500000
parity is : none
databits are : 8
stopbits are : 1
escape is : C-a
local echo is : no
noinit is : no
noreset is : no
nolock is : no
send_cmd is : sz -vv
receive_cmd is : rz -vv -E
imap is :
omap is :
emap is : crcrlf,delbs,
Type [C-a] [C-h] to see available commands
Terminal ready
h\mkjOdw`GfGe'O\beyO#omh]Cd?`;G'mh]Cd`;G'.mh]Cd?`;G'mh]Cd`;G'h;~
============= minicom
Welcome to minicom 2.7.1
OPTIONS: I18n
Compiled on Aug 13 2017, 15:25:34.
Port /dev/ttyUSB0, 00:43:50
Press CTRL-A Z for help on special keys
h\mKjodW`9Gfge'_O\?beyO#o.mh]Cd?`d?h]Cd`d;v
The bold lines are the output when plug in the device.
Seems my device is totally broken? Any idea? Thanks!
My UART is CP2102, supports Baud Rates: 300, 600, 1200, 1800, 2400, 4000, 4800, 7200, 9600, 14400, 16000, 19200, 28800, 38400, 51200, 56000, 57600, 64000, 76800, 115200, 128000, 153600, 230400, 250000, 256000, 460800, 500000, 576000, 921600
RK3328 supports bit rates 115.2Kbps,460.8Kbps,921.6Kbps,1.5Mbps,3Mbps, 4Mbps
I tried a few buad rates, but none worked. Maybe I need a new UART with CP2104?
Guest
Originally posted by linuxerwang View Post...I tried a few buad rates, but none worked...
"With some adapters, you may try to connect TX pin of the adapter to RX pin of the board, and RX pin of adapter to TX pin of the board, if you do not get the serial console working."
source: http://wiki.t-firefly.com/en/ROC-RK3399-PC/debug.html
You can also check the UART adapter speeds with CP21xxCustomizationUtility.
Originally posted by mAtvXk View Post
Rockchip = 1500000 baud rate
Then I use the utility to change the "desired" column of the first two lines to 2,000,000. Program device shows green column. But putty still can not open connection to the port.
Also tried 1,200,000, can't open connection. Tried 921,600 (and lower baud rates), it opened the connection. But connecting the power to the tv box, it shows some random characters.
I guess my UART device only supports up to 921,600, even if programmed to higher baud rates. I ordered UART devices with ch340g and FT232RL, hope they work.
I got a new UART which got some meaningful output:
Code:DDR version 1.16 20190528 ID:0xFFF ln DDR3 333MHz rd addr 0x80000000 = 0xC9D2000F rd addr 0x40000000 = 0x40D200FF rd addr 0x20000000 = 0x20D200FF rd addr 0x10000000 = 0x10D200FF rd addr 0x200000 = 0xF2001D rd addr 0x100000 = 0xD200FF rd addr 0x80000 = 0xDA00FF rd addr 0x40000 = 0xD600FF rd addr 0x20000 = 0xD200FF rd addr 0x10000 = 0xD300FF rd addr 0x8000 = 0xD280FF rd addr 0x4000 = 0xD240FF ERR
There are currently 2411 users online. 0 members and 2411 guests.
