Tronsmart MK-908 dead?
    Hi. I'm new here.
    Got the link for this forum from a friend.
    A few days ago I got myself a Tronsmart MK-908 Mini Android-pc.
    Worked ok. Saw that new firmware with OTA-update option was available.
    Tried to flash the new firmware with Rockchip Batch Tool.
    At first, it seemed ok but now the stick doesn't boot anymore.
    Probably I used the button UPGRADE instead of RESTORE.
    Tried a number of firmwares, but none revive the stick.
    A reseller nearby claims the stick is beyond repair now.
    Is this true or does anyone have a solution for me, please?
    Originally posted by jakenl View Post
    Hi. I'm new here.
    first you need to check in the proper thread for your device . i will move your post to the correct thread sometime today . thanks Tattman65
    freaktab art developer if you like my work please buy me a pepsi
      Hi. I'm new here.
      What type of flasher do you have.. Try re-flashing just the 'Boot' section.. or if you don't have that option Hold down the reset and connect to PC and re-flash using different firmware using a PC flash program... PS you may need drivers for your device for your operating system to notice your device.
        Thanks for your answer. Problem is already solved. I just needed to flash the right stockrom.
        Didn't know there were so many different rom's....
        You can read my solution in MK908-forum.
