Beelink J45 Review
    Beelink J45 Review
    Beelink J45
    Intel Pentium J4205 8GB DDR4 512GB mSATA SSD Windows 10 Mini PC Dual Band WiFi Gigabit LAN Bluetooth USB3.0*4 HDMI*2 2.5 inch HDD Bay
    (From webpage)
    Intel Apollo Lake Pentium J4205
    Pentium J4205 is a quad-core 64-bit x86 desktop microprocessor. It is manufactured on a 14 nm process. The chip operates at 1.5 GHz with burst frequency of 2.6 GHz and has a TDP of 10 W. This GPU incorporates Intel's HD Graphics 505 GPU operating at 250 MHz with a burst frequency of 800 MHz.
    Windows 10
    It is pre-installed with Windows 10 home so that our users are able to enjoy the advanced functions of Windows OS directly. Moreover, the built-in Cortana in Windows 10 can turn Beelink J45 into a work assistant as well as life-partner.
    DDR4 8GB RAM + 256GB mSATA SSD
    DDR4 8GB RAM, 256GB SATA SSD, advantageous in performance, security and reliability.
    2.4G/5G Dual Band WiFi
    With support for 2.4Ghz and 5Ghz band, it can transmit higher amounts of data.
    Gigabit LAN
    Gigabit LAN provides a data rate of 1 billion bits per second.
    Hi Guy's,This time we have another windows Mini PC to Review.The all new Beelink J45
    Windows 10 pro 64Bit opperating system.On opening the box the first thing you will notice is its a tiny device with a mirror black finish to the top and has metal sides and bottom with venterlation holes on both sides.
    It has a aluminum heatsink & a mini fan Giving it a good chance to keep the unit cool,The fan is not running all the time but when it is running you cant notice it.
    Front of box
    Right hand side
    Rear
    Bottom
    The Beelink J45 has all the ports most people will need,The power button is on the front with the head phone jack and 2 USB3 ports.On the right hand side is the Micro SD Card slot and on the rear is the DC 12V input,2 HDMI out,2more USB3 ports,Gigabit LAN and the locking point to help stop someone from running away with your nice new mini PC.
    Ports and locations
    Storage
    Cooling
    The boot time on the J45 is around 15 seconds & that takes you straight to the main windows screen where your ready to go.The shut down time is about 4 seconds.
    What works
    64GB works (Max supported is 64GB)
    128GB USB Stick
    Samsung 1TB unpowered HD works
    Tronsmart Mars G01 Gamepad works
    Logitech c270 webcam works
    Unlike android TV Boxs you will find most things works
    Some internal photos
    Double Driver Backup
    https://mega.nz/#!xTxBEC6S!JzcvUPc9FuJ4ZOCgvqQzWBAw1JhV2XrXjuoO3g-rtxY
    Bios Backup
    https://mega.nz/#!tbhlxSxS!P8tDr1gnrMBcWHCbL1dNm8Z5gwk9p7Bgjc3zd0W r6oc
    Specification
    General
    Brand: Beelink
    Model: J45
    Type: Mini PC
    Hardware
    OS: Windows 10 64Bit
    CPU: Intel Apollo Lake​ Pentium J4205, 4 Cores 4 Threads 1.5Ghz, up to 2.6Ghz, Cache 2M
    GPU: Intel? HD Graphics 505
    RAM: 8GB DDR4
    ROM: 256GB mSATA SSD
    Max. Extended Capacity: TF card up to 64GB (not included)
    Communication
    WiFi: 2.4G/5G WiFi
    Bluetooth: Bluetooth 4.0
    LAN: 1000M
    Media
    Decoder Format: H.264, H.265
    Video format: 4K, 4K x 2K, ASF, AVC, AVI, DAT, FLV, ISO, MP4, RM, RMVB, RV, TS, VOB, VP9, WMV
    Audio format: AAC, AC3, ACC, APE, DDP, DTS, MKA, MP3, MPEG,OGA, OGG, RM, TrueHD, WAV, WMA
    Photo Format: BMP, GIF, JPEG, JPG, PNG
    Support 5.1 Surround Sound Output: Yes
    Interface
    1* DC jack
    4* USB3.0
    1* RJ45
    2* HDMI
    1* Audio Jack
    1* TF card slot
    Internal Connector : MSATA , SATA, PCIE slo
    Other Features
    Language: Multi-language
    HDMI Function: HDCP
    Lithography: 14nm
    Power
    Power Consumption: 12V/2A
    Power Type: External Power Adapter
    Power Supply: Charge Adapter
    Certification: CE, FCC
    Dimensions & Weight
    Product weight: 0.3370 kg
    Package weight: 0.7900 kg
    Product size (L x W x H): 11.90 x 11.90 x 2.00 cm / 4.69 x 4.69 x 0.79 inches
    Package size (L x W x H): 13.65 x 12.90 x 8.55 cm / 5.37 x 5.08 x 3.37 inches
    Some Tech stuff
    Aida64
    Crystal Disc
    Disc Manager
    About Pc
    When i first turned it on it was running windows version 1803
    After a few hours of updates im now running the latest windows version 1903
    Unboxing Video
    Package Contents
    1x Mini PC
    1x Wall mounted bracket
    1x Service card
    1x Hard disk cable
    1x HDMI cable
    1x Power cable
    1x User manual
    1x Activation guide
