A95X F2 Amlogic S905x2 Android 9.0 TV Box Review
Originally posted by baldurg View PostGood afternoon. So I’m thinking of purchasing this device on SwitchOnShop. Do you think it's worth it? Or can you offer another seller?
Originally posted by Mao Runzhi View PostAloha. Not quite sure if this is the right place / shoulder to cry on but this is the device and I am / was / hopefully am a proud owner. It was working properly for about two months and than it stopped. I am not a "power user" so I was not doing anything like gaming or anything that would cause -I don't know - overheating. It was connected via HDMI so I was able to control it with my TV-s remote meaning that it would shut down when I shut down my TV and vice versa. The situation at the moment is that I have tried everything that I could find on Internet or imagined that would work one way or the other and this is my last resort.
1. First I tried to contact the seller on AliExpress to help me solving the problem but after few replies he stopped communication so I gave up that making a mental note that I will not buy anything worth more than 5 USD from AliExpress in the future.
2. Downloaded and tried to flash the firmware with USB cable and with 32GB sd card without any success. With SD card it doesn't do anything and with cable it stops after 7% with error " [0x32030201]Uboot/Get result/DiskInitial error". Firmware and tools I downloaded from many other places, wherever I found A95X F2 on internet I downloaded but with the same result. There's a lot more things i have tried and I would say anything but messing with pins on the chip.
3. Tried to contact manufacturer : without success. This makes me think that these boxes are not really supported by their manufacturers.
Anyway the box is dead except when it is connected with PC via USB and than it have written "boot" on it's screen. Is there anything else that I can do? And how?
Thanks in advance.
Originally posted by kipir View Posthi friends.hdmi is not working.I changed the cable, it didn't work again.
hunting is running.hdmi how to get rid.AV is running
Hello fellow tv-boxers! There was thunderstorm at my place, lightning struck near building and did fry my router and HDMI output on my a95x. The incompatibility of A/V cables/connectors is hard to describe, really idiotic. I have managed to connect some A/V cable and get video from it, but no sound. Then I had idea, got optical audio cable, hooked it up, but no audio from there. Is there something to be configured so audio is enabled?? from optical output?
What would you do in my case? Try to re-solder HDMI pins? What died most probably? Connector or some part of circuit that connects HDMI connector to chipset?
Real buumer, fully funcioning computer... but no output...
Anybody have a rom that fixes the mt7668 WiFi issue from dropping the speed down to 10MBps?
Update: The atvxperience rom was giving me the same wifi issue. I downloaded and used the Automate app to force the WiFi to toggle off and on every hour. WiFi has been working with no issues now.Last edited by Rccm1112; 26 July 2022, 19:55.
This is a very useful and informative article. I learned a lot about how to install TWRP Recovery for Amlogic S905X2 devices. I think TWRP Recovery is a very handy tool for customizing and optimizing Android TV devices. It allows you to flash custom ROMs, backup and restore data, and perform other advanced tasks. I appreciate that the article provides clear and detailed instructions for the installation process. I also appreciate the links to download the necessary files and tools. I will definitely try this method and see how it works.
retro bowl
There are currently 1516 users online. 0 members and 1516 guests.
