I cannot restore system partition backed up via TWRP
    Hi there
    I have a s905x-p212-2gb with android 6 preinstalled and made a backup using TWRP a couple of days ago.
    Now i want to restore to original backup but encounter " ExtractTarFork process endded with error: 255".
    I can restore all partitions individually with success but system.
    tried to make backups again with another box but problem exsist.
    tried with different TWRP versions but no success.
    Is it possible to boot from sdcard and restore system partition using armbian or libreElec ?
    or install another image and unmout system under android and flash system partition?
    because the archive(system.ext4.win) is healthy and i can extract it using winrar or tar.
    and finally restore other partitions using TWRP.
    any help appriciated
    p.s : if yes please guide me through cause I'm not an expert in command line.
