Problem with ROM ACEMAX X96S 9.0
Guest
Originally posted by wongtimothy View Post
Is there a rom directly for v311_P_20191021-2013? I believe this is the only update before v311_P_20200611-1821, and I want to return to the previous launcher layout.
None of these firmware have the leanback launcher in them
but you can a trick to getrid of the bad launcher.
just install the link2sd app then open it and search for the pendoolauncher and Freeze it, now you can install any laucher you want , and it will work on every reboot.
There are currently 2156 users online. 2 members and 2154 guests.
