X96max bad flash, no u-boot, SYS1 pll lock check retry, Stop here...
    Hello,
    i have a big problem after a bad flash.
    I?ve tried to flash a new FW and it bricked.
    Amlogic Burning Tool does not recognize it.
    Amlogic sd recovery does?nt work
    Reset button in the av port no function.
    Shorting the NAND dont work https://forum.freaktab.com/forum/mai...755#post758755
    I have a serial connection to the box and this is the only response:
    Code:
    G12A:BL:0253b8:61aa2d;FEAT:E0F83180:2000;POC:F;RCY:0;EMMC:0;READ:0;0.0
        l2_stage_init 0x01
    bl2_stage_init 0x81
    hw id: 0x0001 - pwm id 0x00
    bl2_stage_init 0xc0
    bl2_stage_init 0x02
    L0:00000000
    L1:00000703
    L2:00008067
    L3:04000000
    B2:00002000
    B1:e0f83180
    TE: 217253
    BL2 Built : 19:22:38, Jun 28 2019. g12b ga659aac-dirty - zhiguang.ouyang@droid04-sz
    Board ID = 1
    Set A53 clk to 24M
    Set A73 clk to 24M
    Set clk81 to 24M
    try t0...
    try t1...
    Stop here...
    Do anyone see hope or is the box dead?
    Thanks in advance
    derBG
    My x96max 4/64 also became bricks. I opened the short-circuit circuit of the box and flashed the x96max original firmware back, but I have been testing for short-touch. I only know that two of the contacts are correct. I'm not sure which two, if you still need it, I will send you pictures and flashing methods. The text is translated from Google into English by Google, I hope you can understand, please understand that I do not speak English
