I'm assuming I could add an antenna if I could figure out what solder points to use. Any ideas?
mk808c where is the antenna?
So I have an mk808c with the Allwinner A20 chip. It works okay, but the wifi signal is very poor. Unlike what I've seen in pictures for other mk808 models, this one has no antenna wires soldered on the board at all.
I'm assuming I could add an antenna if I could figure out what solder points to use. Any ideas? -
AW: mk808c where is the antenna?
When you look on the 3 Picture where you see the WiFi PCB on the right side are 2 Solder Pads on the bottom take a paper clip on one of them and see if your WiFi Signal gets better. If yes you have found the Point where you can solder a Antenna Cable.
Neomode
There are currently 2199 users online. 0 members and 2199 guests.
