s905w p281 bricked only red light
As the title says, my MXQ 4k pro is bricked. I was trying to flash a rom, pressed the reset button with the SDcard in and then plugged the power cord, the update screen showed up for like a second but because I haven't stopped pressing the reset button it instantly got interrupted. The led light turned red as if the box is off and the remote is broken so I can't try to press the on button on the remote. Usually the box turns on as soon as I plug the power cord but now it's just stuck there with the red light. I then tried plugging it through USB to my computer but windows doesn't seem to detect it at all. Any help?Tags: None
There are currently 1480 users online. 2 members and 1478 guests.
