NEW Beelink T4 Mini PC
    Beelink T4 New Desktop Mini PC - Black 4GB RAM + 64GB EMMC
    Intel Atom x5 - Z8500 Intel HD Graphics 600 / 4GB RAM + 64GB EMMC / 2.4GHz + 5.8GHz WiFi / 1000Mbps / 2 x USB3.0 / BT4.0 / Support 4K 30fps
    Description
    Beelink T4 Mini PC comes with chipset Intel Atom x5 - Z8500 CPU, and it provides you a smooth experience to watch the videos or play games, with USB 3.0 port, make the transmission faster than before. Its faster speed gives you higher working efficiency. On the other hand, T4 is also the best choice for your family entertainment, you can have your family members play games or watch TV shows together.
    Main Features
    ● Powerful processor
    Equipped with Intel Atom x5 - Z8500 CPU which is advanced in image processing and computing. Its high machine configuration gives you ultra-fast running speed and smooth image processing performance. With the HDMI 2.0 data output, it makes sure you can enjoy 4K x 2K Even 3D HD movies.
    ● Advanced operation system
    Support for fast and powerful Win 10 operation system. Perfect for working, watching TV and playing games. Rapid, stable configuration coupled with the highly Win 10. Support dual-screen, reduce the waiting time, improve your work efficiency. Say goodbye to the System freezing and buffering.
    ● Convenient to use
    Support multiple connections such as Ethernet 1000Mbps, standard RJ 45, Bluetooth 4.0 and 2.4 / 5.8GHz WiFi. It is very easy to install, as soon as you plug in the power supply and connect the box to your WiFi or else way, you can Watch whatever you like. Users can surf the Internet with browsers and have a communication with the world through kinds of APPs, like YouTube, SKYPE video call, MSN, facebook, also the hot films and TV shows can be searched at any time.
    ● Practical multi-media player
    A practical home streaming media player, feel free to enjoy all your favorite movies, sports shows, and entertainment programs. And you can also save the games, movies and TV shows you like, support the SD card extended to 128GB ( not included ).
    Performance Parameter
    - Work environment: -10 - 45 Deg.C, 30 - 90 percent humidity
    - Storage environment: -20 - 60 Deg.C, 10 - 90 percent humidity
    - Built-in CR2032 210mAh battery
    Specification
    Brand: Beelink
    Model: T4
    Type: Mini PC
    System: Windows 10
    Core: Quad Core
    GPU: Intel HD Graphics 600
    RAM Type: LPDDR3
    Decoder Format: H.263,H.264,H.265,HD MPEG4
    Video format: 1080P,4K,DAT,FLV,MKV,MOV,MP4,WMV
    Audio format: AAC,AC3,MP3,MPEG,OGA,OGG,TrueHD,WMA
    Photo Format: BMP,GIF,JPEG,JPG,PNG,TIFF
    Support 5.1 Surround Sound Output: Yes
    5G WiFi: Yes
    WIFI: 802.11 a/b/g/n/ac, Dual-band WiFi 2.4GHz/5GHz , Dual wireless antenna
    Bluetooth: Bluetooth4.0
    Power Supply: Charge Adapter
    Interface: DC Power Port,DP,HDMI,Microphone Jack,RJ45,USB2.0,USB3.0
    Language: Multilanguage
    HDMI Version: 1.4
    Other Functions: Others
    HDMI Function: HDCP
    Power Consumption.: 12W
    RJ45 Port Speed: 1000Mbps
    Power Type: External Power Adapter Mode
    Power Input Vol: 12V
    Suggest Input: 12V 2A
    Power Adapter Input: 100-240V / 50-60Hz
    Product weight: 0.2500 kg
    Package weight: 0.6600 kg
    Product size (L x W x H): 10.60 x 10.60 x 1.77 cm / 4.17 x 4.17 x 0.7 inches
    Package size (L x W x H): 14.60 x 12.40 x 7.00 cm / 5.75 x 4.88 x 2.76 inches
    Package Contents: 1 x Mini PC, 1 x Power Adapter, 1 x Mini PC Bracket, 1 x English User Manual
