Need Firmware HK1 PLUS S905X2 4/32GB?
Thanks RiCkLaR_atvX, not bricked yet, but box acts misbehaving like app crash, restart some time etc, please tell me can we flash other brand but same spaces firmware like x96 max or h96 max x2 etc over HK1 PLUS ?
X96 Max - https://www.aliexpress.com/item/3294...390b493bwiXyaj
H96 max x2 - https://www.aliexpress.com/item/3295...2ec254a30irqUj
The stock original firmware has lots of Apps 'crashing' ? Maybe your Google Play services needs update. Make sure is correct version by installing the app "Play Services Info" that app will redirect you to Google Store and you can download/install the correct version.
Or flash a TWRP recovery and see if the latest Gapps Zip will install.
But, if you wanted to flash a different boxes firmware it may be possible that the T10_Pro or H96max_X2 firmware will work for your device. From what I read of the other user having the similar device Bqeel that those TV boxes always has issues with different manufactures firmwares, problems like no wifi or no ethernet if they even boot at all, so is a gamble when you try different manufactures firmwares. If you can find the Bqeel firmware that would probably be the closest compatible firmware to your device.
The most recent stock firmware update is here...hope it works for you.
Updated stock Android Pie firmware for H1 Plus S905X2 for both 2GB and 4GB ram versions. HK1 Plus.png Filename is u217.HK1_PLUS_100M_9.0.2019.12.03.15.22 Download here: https://mega.nz/#!1Jsh1azB!GGGDlomqo...mrcKeGg8YFXx3s (https://mega.nz/#!1Jsh1azB!GGGDlomqogRaRQS3Hl27utzOkVVrSmrcKeGg8YFXx3s) Burning tool. https://mega.nz/#F!JHK1 Pro Plus
FlowFon F1
H96 Pro+ (Wisdom-Green Board-2017-02-10 H96-S912-TVBOX(DDR4)-V0.2)
MXQ Pro+
R-TVBOX Mini+
MK809III
There are currently 1420 users online. 0 members and 1420 guests.
