4/64 for on 39.99 Hmm would run linux maybe and other stuff has to be worth a look me thinks
https://i.imgur.com/b2FeADW.png
[IMG2=JSON][][/IMG2]
https://www.gearbest.com/tv-box/pp_0...&lkid=53925152
Description
Magicsee N5 NOVA smart Android TV box with 2.4G Voice Remote is your great choice and can change your traditional TV and LCD monitor into a multimedia center by connecting the internet ( via WiFi or RJ45 ). This smart TV box will bring you much fun and convenience with its powerful.
Note
1. Steps to close the Airscreen application notification message box
● Select "Settings" - Choose Apps - Select "Airscreen"
● After the Notifications is set to off, the Airscreen application notification message box will not be displayed. If you reset the factory settings, please repeat the above steps again.
2. Steps to close the Netflix upgrade prompt
● Open the Netflix APP
● The update prompt window will pop up on the interface. Please select the "Cancel" - "OK", then Netflix upgrade prompt will not prompt. If you restore the factory settings, please repeat the above steps again.
Main Features
● Android 9.0 OS And RK3318 Quad-core 64-bit ARM CortexTM - A53
Comes with Android 9.0 OS, powered by the high-performance RK3318 quad-core CPU, including a Mali-450 GPU.
● 4GB RAM 64GB ROM
4GB RAM 64GB ROM provides plentiful room to quickly run the device. Supports TF card reading up to 64GB, it also greatly improves the reliability of your TV box.
● HEVC H.264 And VP9
H.264 and VP9 hardware decoding can save 50 percent bandwidth resources, let you watch the 4K movie smoothly. Every detail of the screen is lucidity.
● UHD 4K Resolution
Supports 4K UHD video hardware decoding, which provides you high definition viewing and fluent video playing, making it as the highest resolution signal available for home movies.
● Voice Remote Control
Press the voice button on the remote control to search for what you want, such as the best action movies, today's weather or the latest news.
● Your Own Home Theater
Once connected Magicsee N5 NOVA Android TV BOX With 2.4G Voice Remote with your WiFi or RJ45, your HDTV becomes into a smart streaming machine, making home entertainment easier.
