Purchased it 20 days ago...
Beelink GT King dead
Originally posted by Ajvan View PostI have tried different hdmi cable, and change port on TV.
The skull is lightning green. The remote is working. I have tried reinstalling firmware. And still nothing. No picture.
And, you could also, give CoreELEC a try as a last resort. All you need is a microSD card or pen drive, and a computer to burn the CoreELEC OS to the microSD card.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
If it is a 4k TV, you may want to try on a NON-4k TV. I had that issue on one of my other boxes, it would NOT display on my 4k TV, had to set it up on a 1080p TV.
Dont have a pc either.
Originally posted by Ajvan View PostI mean cant insert sd card to pc
Once you have the OS installed on your sd card, put the card into your "King". There is a reset hole on the bottom of your "King", depress and hold it for about 15 seconds after you plug in the power to your "King". It should boot into coreELEC. It does NOT touch your Android you already have installed. That will tell you if your box is still functionable.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
The operating system will be on your microSD card. You have to use a computer running Rufus to create the OS, so you need a sd card reader attached to your computer. You download and install Rufus. Go the CoreELEC website and download the nightly ( https://relkai.coreelec.org/ ) for for your box. Get the one with this name. "CoreELEC-Amlogic-ng.arm-9.1-nightly_20190831-Generic.img.gz".
There are currently 1394 users online. 0 members and 1394 guests.
